‎11-08-2017 07:32 AM
I have a vi that searches for a file on C:\FolderA\FolderB using "Check if File or Folder Exists.vi." It can't see the file and returns with a FALSE (does not exist) when it is clearly there. I've tried to change permissions, but every time Labview 32-bit 2015 checks, the permissions seem to change back. I'm wondering if this has something to do with the fact that I'm running on a 64 bit Windows 7. I haven't found any posts that go into Labview not being able to see a file in this way.
I am also trying to run a batch file following this. Wondering if I need to run as admin for that but haven't made it that far yet.
‎11-08-2017 08:00 AM
I cannot test the VI you failed to post, but I have LabVIEW 2012, 2014, 2015, and 2016 (all 32-bits) running on my 64-bit Windows 7 and have never seen this problem. This has to be a rather frequently-used function, so I cannot think that it is truly faulty -- a more parsimonious assumption is that either your code is "wrong" (cannot judge, as cannot see, cannot test) or there is something very unusual about your environment (again, no code to test).
Here's what I did:
Since you have the VI That Fails, what are you doing differently?
‎11-08-2017 09:53 AM
Please don't start conspiracy theories about windows bitness. Yes, permissions could be a problem, depending on where the file is located. Even if you have admin permissions, LabVIEW still does not unless you start LabVIEW with "right-click...run as administrator". That would be the first thing to try. Why didn't you yet?
Also look for unusual characters in the file name. How are you entering the path (path control? string followed string-to-path? Dialog?)
‎11-08-2017 11:17 AM
The satisfaction with developing software is that the software you develop does exactly what you tell it to do.
The frustration with developing software is that the software you develop does exactly what you tell it to do.
‎11-08-2017 02:49 PM
Word of the day: parsimonius
Definition: unwilling to spend money or use resources; stingy or frugal.
‎11-08-2017 04:36 PM
... and here I thought you were being critical of my spelling (which, I just checked, is correct) ...
Bob "Moderately Generous" Schor
‎11-08-2017 04:42 PM - edited ‎11-08-2017 04:43 PM
One could say that I might not have known what that word meant. ![]()
