Check if excel workbook open ActiveX and obtain workbook reference
If the workbook is open, then you make it active..
If the workbook is not open, then you would open it and make it active.
To open a workbook or to make a workbook active, you need to use the Invoke Node.
A workbook is essentially the Excel file.
Message 11 of 14
(1,164 Views)
I may not be explaining this well.  The problem I am having is how to make a specific open workbook the active one.  I can only find the ActiveWorkbooks or ActiveSheets property under the Application reference, and these are writes not reads.  How do I tell it to make a specific open workbook the active one?  If I use the Activeworkbooks or Activesheets property it just selects the workbook that was last active.  I want the program to make a specific workwook active.
Message 12 of 14
(1,156 Views)
If you absolutely certain that the workbook is open, then just activate it with an Invoke Node. That makes it Active.
You should go back and look at whatever VI you are using and understand what is happening.
Properties are not the way to go.
LabVIEW's ActiveX Invoke Node which translates to Methods are the way to go.
Message 13 of 14
(1,148 Views)
I have also tried the invoke node but I get an undefined error.  When i research the error it appears to be a Microsoft Office issue.  Unfortunately this program will need to be able to operate on many laptops all running various versions of Windows..
EDIT: Actually, it now works.  Hopefully this will be true for all our computers.  Thanks
Message 14 of 14
(1,135 Views)
