06-27-2024 01:41 PM
I know that this should be simple, but I am not converging to a simple solution.
I would like to just generate a TRUE value if there is a duplicate value in an array.
This is what I have thus far (but doesn't work):
Can you offer some guidance as to a simple elegant solution to return TRUE if there is a duplicate?
Thanks for your help and time!
06-27-2024 02:03 PM - edited 06-27-2024 02:08 PM
The following code should work. This is going to run O(n^2) so It'll get really slow for larger arrays, but I'm not sure you can do much better with unordered arrays.
06-27-2024 02:18 PM
06-27-2024 02:29 PM
Didn't even know there were sets in LabVIEW, so thanks! This is a better solutions than mine for sure.
06-28-2024 03:22 AM
It was added in 2020 or something.
06-29-2024 01:41 PM
This code makes absolutely no sense!
Yes, Maps and Sets were introduce in LabVIEW 2019, have a look at my presentation for details. They offer a good solution.
Even without the use of a set, this will probably OK for typical scenarios:
07-01-2024 08:34 AM
Without sets this is possibly a better solution with a runtime of O(n*log(n)), though it might lead to the array being copied.
07-01-2024 10:00 AM
Yes, sorting first can be an advantage for very large arrays and very few duplicates, but why would you need two instances of index array and that +1??? It is sufficient to resize to two outputs and wire [i] to the top index and the second one will automatically be [i]+1.
You can also delete the first element, autoindex over the rest, and compare current to previous. Here are two possibilities: Version B is your example, but cleaned up a bit. 😄
07-01-2024 10:27 AM - edited 07-01-2024 10:50 AM
Be aware that anything that relies on an equal comparison will not be able to tell if there are duplicate NaNs in the array.
If that is a concern, the "set" or my earlier version will still work correctly!
07-01-2024 11:21 AM
Could be a relevant edge case, though checking floating point numbers for equality is code smell and usually a bad idea IMO. I assumed that we're just using floating point in these examples because it's the default.
