Check a target machine (Windows only) for Vision RTE
How do I check a target machine (Windows only) to see if the Vision RTE is installed?  When installing a machine vision program, I have to download and run two LV RTEs (8.5 and Vision 8.5).  I'd like to make the process as painless as possible.  And I don't want to install the RTEs if they're already on the machine.  Is there a registry setting that I can check as part of the install?  I'm not using the LV deployment engine.
(3,400 Views)
Hi ST1
a think what you want is available under this registry key: "HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Uninstall"
Here is a script for a batch file which list all entries from this registry key. i found it on this web page:
http://forum.fachinformatiker.de/windows-betriebssysteme/61021-installierte-software-auflisten.html.
Script:
"@Echo Off
    Start /Wait Regedit /E %TEMP%.\Tmp HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Uninstall
    Find "DisplayName" < %TEMP%.\Tmp | Find /V "QuietDisplayName"
    Del %TEMP%.\Tmp
pause"
I hope this helps you.
Mike
(3,388 Views)
Mike,
Thanks.  That looks like what I need.
(3,372 Views)
