Chart X axis time
Hi all,
I'm working with CRIO.
I need to display with a chart:
- y axis: two double measures
- x axis: data and time of every point
Can you help me?
Thank you
(2,565 Views)
Hi Simone,
which cRIO do you use? Usually they don't support any monitors so it makes no sense to show a chart…
Why do you insist on a chart? Why not use a waveform graph with X axis set to absolute time?
(2,562 Views)
Hi GerdW,
than you for your reply. I was wrong to write...waveform chart!
Have you got an example?
Thank you
(2,553 Views)
Hi Simone,
LabVIEW comes with a huge example library.
There are also example VIs showing how to use charts and graphs…
(2,538 Views)
