Chart X axis--Current time
I am trying to plot hourly data. However I am unable to set the x axis to display the time the data point is sent to the chart. I have attempted to use property nodes but I'm not familiar with using this technique. See vi for details.
Message 1 of 55
(6,458 Views)
Right click the chart, select properties and then change the time to relative or absolute.  Use absolute for "clock" time.
EDIT: It's on the Display Format tab.
Message 2 of 55
(6,452 Views)
NIquist,
That doesn't seem to work. The "clock" time is erroneous, instead of displaying the current date and time it displays Dec. 31 at 19:00 as the start time. I attempted to adjust the x axis manually but that didn't work either. Were does it take the time from...the PC or the device?
Message 3 of 55
(6,441 Views)
You need to set the offset of the x-axis with today's date and time.
Message 4 of 55
(6,437 Views)
try to use property node like the example!
Anderson M. Takemoto
Instituto de Pesquisas Eldorado
Message 5 of 55
(6,431 Views)
Thanks for the example I will give that a try.
Message 6 of 55
(6,430 Views)
That example does nothing to set the X axis to the current time.
Look at the shipping examples. There is one called Real-Time Chart.
Message 7 of 55
(6,425 Views)
Dennis I looked at the example but I am unable to make it work in my application. Is there another way?
Message 8 of 55
(6,391 Views)
Not unless you show how you modified your application.
Message 9 of 55
(6,383 Views)
OK, I will not be near the PC until Monday...I'll upload the VI then.
Message 10 of 55
(6,372 Views)
