Channel writer option not showing
I am new to channel writer in loops. When I right click a terminal or node and select 'create', there is no option for channel writer.
I am using Labview 2013. Is there a module I need to download?
(1,226 Views)
Accepted by ChiDoe
It is not clear what you mean by "channel writer".  If you are referring to "Asynchronous Channel Wires", they were widely introduced in LabVIEW 2016.  There is no possibility of using them in LabVIEW 2013.
If you are really interested in using this feature (one which I use pretty heavily, myself), I recommend that you upgrade to at least LabVIEW 2020, as the Developers were making a few "tweaks" in the Channel Wires in the earlier versions.
(1,217 Views)
