‎08-04-2014 03:10 PM
I am in a situation where I need to use subpanels to dynamically link subVIs for data entry. I also like to have the calling VI be able to modify the strings[] parameter of several of the enums in the subVI, but this does not appear to be possible as the subVI is not in edit mode. Does anyone know of a way around this?
I'm reading data from a file to initialize the enums, so I could have the subVI read the file instead, however I was hoping to do it once in the main VI and send the strings to the subVIs to speed up execution.
Thanks!
‎08-04-2014 03:14 PM
Use rings instead of enums.
‎08-05-2014 06:38 AM
That's impossible. Enums are set in stone at runtime. Oh wait, you are trying to use scripting at run-time. Sorry, that doesn't work. Notice that the property node for the Strings[] for the enum is blue? That tells you that it is a scripting node and only useful for editing VIs during edit time.
As RavensFan said, you need to use a Ring. Their data type is an actual number.
