Changing the oscillscope from Tektronix TDS 210 to Tektronix TDS 3032C
I am using my own Labview program to collect data from Oscilloscope.I changed my oscilloscope from Tektronix TDS 210 to Tektronix 3032c. The signal from the Tektronix TDS 3032c has a huge noise now. The singal can be seen only when the probe setup is 1kx.But I have a smooth signal with my old scope.Can this be due to the settings of new scope?If so what are the parameters I should try changing.
Thank you
(3,449 Views)
Don't know.  Guess it's time to break out the programmer's guide to figure out what's changed.  Unfortunately I don't have the 210 manual or I'd be more specific with my help.  😞
Bill
CLD
(Mid-Level minion.)
(3,422 Views)
You really shouldn't be changing the probe setting unless you are changing the probes.  I seriously doubt you are using a 1kx probe.  But now you got me wondering.  I might have to go play with some of my setups when I manage to find some time.
There is a bandwidth setting.  You could change that to a lower bandwidth.
Digging a little bit I found that the TDS210 has a bandwidth of 60MHz and the TDS3032C has a bandwidth of 500MHz.  Try the lower bandwidth settings and see if that helps.  I'm 95% sure this is a wider bandwidth issue.
GCentral
(3,414 Views)
Here the manuals..... Can you give some help...... (y)
(3,393 Views)
I'm digging through code I did for the 3034C.  To set the bandwitdth you need the following command
CH1:BANDWIDTH BW
 where CH1 is the channel (you can use CH2, MATH, etc.) and BW is the bandwidth setting.  Available bandwidth settings I have are:
Full Bandwidth: FULL
150MHz: ONEFifty
20MHz: TWENTY
So my guess for what you want is
CH1:BANDWIDTH TWENTY
GCentral
(3,390 Views)
This did not help. 😞
(3,371 Views)
Probably time to see some code.
Bill
CLD
(Mid-Level minion.)
(3,367 Views)
