Changing slider maximum scale programmatically
Is it possible to change a slider scale maximum programmatically - it appears that this value is not a write value using property nodes?
(4,637 Views)
An important note - I have the slider set up as a strict type def so I guess this is why I can't change the value...
(4,637 Views)
I am including a vi which programmatically changes the minimum, maximum, start values for a slider scale.
If your problem is different than what I have answered, pl. give the feedback.
Best Regards,
Nirmal Sharma
India
(4,637 Views)
You are correct!
That gives you two options;
1) Right clcik and choose disconnect from typdef,
or
2) Customize control and make it a normal typdef.
Ben
(4,637 Views)
