Changing ring programmatically
Hello everyone,
in my little program here I want to get certain strings in the ringselector indicated by a boolean element called channel.
A possibilty out of many:
If I select channel 1, 2 and 4 should be on and 3 off, I want that in the ring channel 1, 2 and 4 only can be selected and also that there are only 3 selection items in this ring. The true case works fine but the false case not really. I don't know how I can delete the not selected channel and also get the certain display in the ring.
I hope anyone can help me.
Soleil20
(3,488 Views)
Accepted by topic author Soleil20
If you want to delete uncheck items
(3,486 Views)
Thanks a lot zxcpavel! I thinked to complicated.
Soleil20
(3,478 Views)
