Changing an output box in a case structure to an input box
Hi, I was working on a wiring diagram in Labview and I was trying to
wire an absolute value symbol to the right border of a case structure.
The problem is that I get an output box (an white filled box with an
orange border) instead of an input box (an orange filled box). How
would I change the output box into an input box?
Muhammad Asfour
Message 1 of 9
(3,549 Views)
I'm not sure I understand what you are asking. Where is your constant? If it is inside the case structure then it can't be an input to the case.
Message 2 of 9
(3,549 Views)
Brian Can you please give me your e-mail address so that I can e-mail
you a screenshot of what I am talking about?
Muhammad Asfour
Brian Vibert wrote in message news:<506500000005000000CD800000-1023576873000@exchange.ni.com>...
> input to the case.
Message 5 of 9
(3,549 Views)
A wire can have only one source.
If the source is outside the structure, the "tunnel will be an input. If the source is inside (any of the cases), you will have an output tunnel.
Bottom line:
The location of the source will determine if the tunnel is an input or an output.
Ben
Message 3 of 9
(3,549 Views)
Muhammad-
There is no difference between an input and an output box, they are the same thing. The white box indicates that not all the cases in your case structure have an input wired to the box. Go to the other cases, right click on the box and select create>>constant. Once all the cases have an input wired, the box will become solid.
Ray Kong
NI Applications Engineer
Message 4 of 9
(3,549 Views)
Ray, I tried your method it still does not work. Any suggestions?
Muhammad Asfour
Ray K wrote in message news:<50650000000500000024810000-1023576873000@exchange.ni.com>...
> Muhammad-
> Ray Kong
Message 6 of 9
(3,549 Views)
Muhammad Asfour
> Muhammad-
> Ray Kong
Message 7 of 9
(3,548 Views)
Muhammad Asfour
> Muhammad-
> Ray Kong
Message 8 of 9
(3,548 Views)
Next wire the constant.
Ben
Message 9 of 9
(3,548 Views)
