Changing Tab Text
How can I change programmaticly the Text of the Tabs from a Tab Control?
I was looking for a property like "Strings[]" from the "ring-control"
I need a soloution to to dynamic change the Tab control during execution.
Any idea?
(2,867 Views)
ISTR there's very little control over the tab control. However, you could
hide the tabs of the tab control, select which tab is to be displayed
programmatically, and create at the simplest a cluster of Booleans at the
top to serve as a new tab control.
Amadeo Vergss wrote in message
news:3a7e7be4@newsgroups.ni.com...
> Any idea?
(2,867 Views)
In Measurement Studio 6.0 you can access a function EasyTab_SetTabAttribute with the attribute, ATTR_EASY_TAB_LABEL_TEXT, this parameter takes a string and allows you to change the tab-text programmatically.
Good Luck
Elaine R.
http://www.ni.com/ask
(2,867 Views)
