Changing Labels
And when I click "Description and Tip" it looks like this.  I don't know what it even means but There is nothing there and the windows cannot be typed in.
Message 11 of 36
(1,661 Views)
As I said, you have to stop the VI before you can edit the list. You can't do anything while it is running. Click the 'Exit' button.
This is extremely basic LabVIEW knowledge. You need to spend some time learning these basics. One place to start is http://www.ni.com/academic/lv_training/how_learn_lv.htm. You can also try http://www.ni.com/swf/demos/us/labview/getting_started_lv/.
Message 12 of 36
(1,648 Views)
Dennis advice is spot on. My question is if you depress the exit button does the front panel (user interface) go away? If it does try to hold down the Ctrl button and hit the (.) period button. This might put you in a editable mode. If it doesn't the application may have been built as a executable which means you would need to edit the source code and rebuild the application.
Now Using LabVIEW 2019SP1 and TestStand 2019
Message 13 of 36
(1,638 Views)
do you want me to change it , it will be done in a minute, give me the value you want to modify
Message 14 of 36
(1,630 Views)
Bob I think you're correct.  I just got back from lunch and will go to that workstation shortly, but yes it does close when I hit the exit button.  From what I can tell it runs always.  Data is always being collected but that is through ASI Datamyte; Labview is used more as an alert mechanism so that we know when something is out of spec.  If I have to change the source code I am going to be really lost.
Message 15 of 36
(1,622 Views)
There is code in there that will close it if it's an exe and I suspect that is what you are actually running. You did post the source code with the top level VI called 1665 Main and that will just stop if you click on the 'Exit' button. If you do manage to edit the source code, then you would also have to rebuild the executable. Modifying the source code and creating a new exe is not really all that difficult.
Message 16 of 36
(1,616 Views)
Ctrl+. will stop the application if it works. This might not be desirable during production.
Message 17 of 36
(1,614 Views)
Yeah Ctrl +. didn't work either.  So where would I start to change the source code?  Unfortunately I cannot access this forum and do it at the same time...I have to go all the way across the production floor to the computer.
Message 18 of 36
(1,611 Views)
Have you actually read my responses? I told you which VI to open in the source code you provided and how to view the list. YOU HAVE TO FIRST DETERMINE WHETHER THE PROGRAM ON THE PRODUCTION FLOOR IS AN EXE! If it closes the window when you click on Exit, it is and you can't do a thing there.
Message 19 of 36
(1,602 Views)
Yes I have.  The problem now is that the source code is password protected.  We are trying to get in touch with the person who made the password who is no longer employed here.  I cannot do anything until then.
Message 20 of 36
(1,595 Views)
