Changing Key Focus Color and/or Size?
Is it possible to change the size and/or color of the default black border that indicates a front panel object has key focus? I have an application that requires the user to be a larger than normal vieing distance from thwe monitor and the key focus is difficult to see.
 I've attached an example of a work-around I developed, but it's pretty unwieldy to implement for the large number of controls I'm using.
Thanks!!
Matt
(4,631 Views)
Matt,
I don't know of any way to change the color or size of that key focus default box.  However, one thing that you can do is to put a button behind the control that is going to be in key focus.  Then, use the key focus true/false value to make that button visible or not.  Then, the color of that button can be changed to whatever color you would like.  Hopefully, this will work for you.
-jeff
(4,611 Views)
Hi Jeff,
That's certainly easier than my method. Here's a little something I threw together as a demo.
Thanks!!
Matt
(4,608 Views)
Matt,
That's awesome!!  Your example VI works great!! Smiley Happy
(4,600 Views)
Has anything changed since 2005? Can I modify the focus color or size now?
Greetings,
shb
Message Edited by shb on 12-02-2009 06:23 PM
(4,287 Views)
Nope.
But Darren submitted an idea in the LabVIEW Idea Exchange, so if it get enough votes it might show up in the next version of LabVIEW.
(4,265 Views)
Highlighting may be useful see here.
You could hit it repeatedly to really draw their attention.
Ben
(4,259 Views)
