04-18-2013 11:42 AM
Hi guys ,
Can you please suggest me , how to change controls from normal style to silver style by selecting on the whole?
Because i have to replace each n every control by the replace option?
04-18-2013
12:20 PM
- last edited on
11-14-2024
03:01 PM
by
Content Cleaner
http://digital.ni.com/public.nsf/allkb/2827D5777B012B2886256F2A0073F71A
Unfortunately not, as you can see here.
Chris
04-18-2013 12:30 PM
Ya i have tried , I was just wondering whether is there any other way.
04-18-2013
12:45 PM
- last edited on
11-14-2024
03:02 PM
by
Content Cleaner
A faster way of replacing controls is using the quick drop shortcut.
04-18-2013 12:58 PM
It seems that you can replace multiple controls using the quick drop method. Just select the controls you want to replace, press Ctrl + Space to open quick drop, then select the control you want to use.
04-18-2013 02:29 PM
A long time ago I made a utility to do that. Never used it much. Can't remember how far I got in debugging it. Have fun.
04-19-2013 04:04 AM
nice idea
04-19-2013
06:47 AM
- last edited on
11-14-2024
03:02 PM
by
Content Cleaner
as already mentioned, the Quick Drop method seams to be the best solution for you.
The only alternative is to replace each button individually.
Is this a solution for your problem?
Do you have other questions?
