Change string indicator background color when in focus
Hi, I know how I can change the background color for a string indicator using property Text.BGColor.
My question is how can I change this only when the indicator is in Focus, I mean when the cursor is in that field.
As soon as the cursor goes to another string indicator I would like the color to follow the cursor so to say.
(5,021 Views)
Use an event structure with the Mouse Enter and Mouse Leave events. You could combine all the events in to one event case and use the Control Reference output for the event to change the specific control's color.
Cheers
(5,016 Views)
Accepted by hasse
1. Go give this idea a Kudos: Key focus Event
2. You could do something like this in a loop
(5,004 Views)
That idea deserves Kudos indeed.
If your user will be tabbing between controls, OP will have to poll the focus just like crossrulz suggests.
If mouse events will be satisfactory, the best way to do this would be with an event structure, so your polling isn't using up processing power.
Cheers
(4,996 Views)
Thanks, that works exactly as I wanted. Thanks also James for your input.
(4,972 Views)
