Change file name and VISA serial port in LabView installer/application
There is another option for the COM port portion that has not been discussed here; however it depends on your instrumentation. You would do the following:
  1. Use VISA to get a list of possible serial ports - the list is returned as an array.
  2. Loop through all of the ports using an identity command, such as *IDN?, to identify your instruments. (This part depends on your instruments as they may not support the command)
  3. Assign ports based on the identity command.
  4. Now you can dynamically assign ports at startup, no ini file, no asking your user to configuration anything.
Cheers,
mcduff
Message 11 of 14
(1,184 Views)
Thenk you very much for all the answers!
I have managed to write a .ini configuration file and save my SavingFile path in it.
How can I now write a VISA refnum in the file config? If I write it as a string, is there a way to transform it in a refnum again in my MAIN VI?
Message 12 of 14
(1,177 Views)
Just write the string back into the VISA reference, it will convert it for you.
Message 13 of 14
(1,171 Views)
Perfect! Thank you very much! 😄
Message 14 of 14
(1,168 Views)
