Change dimensions of an string indicator depending on string length
please see the attached VI!
Message 1 of 10
(4,901 Views)
you can use the width property node for the string indicator to set the width of the indicator... with a little experimenting you can calculate the width you need depending on the font you are using...
Good Luck
Dan
Message 2 of 10
(4,898 Views)
Hi Dan,
yes, of cause. I did already.
But the problem is, I want to the application with different languages. The strings (all labesl) are saved in a file wich the user can edit. For example in english "Ready" means in German "Betriebsbereit".
If you see the attached VI, the indicator is used as a title of a section (windows style). The indicator is laid over the frame, if it´s to long and a short string is shown, the frame don´t look good! See the attachment!
Message 3 of 10
(4,896 Views)
something like this wont work for you ??? it makes the indicator just big enough to fit your text... or am i missing something ??
Dan
Message 4 of 10
(4,884 Views)
also if you can use one of the true type fonts it would make your width calculations easier since each character is the same width i believe...
Dan
Message 5 of 10
(4,879 Views)
Yes, this works.
I did it like your way before, but the next time the language might be french or spanish etc., and the strings differ in their lenght.
I´ll try true type fonts and use the "sting lenght" function. Maybe it will work for any lenght.........!
Thanks for you help!
Message 6 of 10
(4,874 Views)
Try this example. I even gave you the ability to fudge my answer how you want 🙂 This solution involved the use of a picture.llb function called get text rect.vi. This will give you the size that you need for the string you pass in and then you can adjust the size appropriatly using the control width properties. The fudge factor is included to account for the border of the string control. We found that about 14 pixels is appropriate. Hope this helps. I give credit to Ben and Kazuo for helping me with this one!!! Go Team!!!
BJD1613
Lead Test Tools Development Engineer
Philips Respironics
Certified LV Architect / Instructor
Message 7 of 10
(4,869 Views)
forgot to attach.. 🙂 sorry
BJD1613
Philips Respironics
Message 8 of 10
(4,868 Views)
Thats the solution!!!!
Message 9 of 10
(4,856 Views)
Here is it as a SubVI.
Maybe someone can use it, too.
Message 10 of 10
(4,815 Views)
