Change default splitter parameters
Hello folk!
I'm wondering if I could tune my LabVIEW to always create new splitters with scrollbars always Off by default and thickness as skinny as possible.
We can do it manually but especially for thickness it might be painfull to reach the correct pixel where I can resize it.
Cheers!
Jimmy
(3,228 Views)
Hey Jimmy,
You should be able to do this using property nodes. The following KnowledgeBase article outlines the process for implementing this in LabVIEW:
'How Can I Programmatically Show or Hide the Front Panel Scroll Bars'
Hope this helps!
~~ Q ~~
(3,164 Views)
