Change Tab Control with external boolean
Hello!
I need to control an event structure with a signal boolean external (Modbus), the event control will have to be independent of the user action.
I tried to use the Property Node "Val (Sgnl)", but was not effective.
Tks!
(2,648 Views)
Can you share some code? What happened when you say it wasn't effective? Did the property node return an error? The event structure is registered for value change events on that control?
(2,630 Views)
Latch Booleans can't have their value set. Not by local, not by a property. Locals break the VI, property nodes will return an error.
(2,600 Views)
