Change RT controller in example
We have a NI example program that sounds like a good fit but the example uses a cRIO 9011 and we are using a 9014. Do we have to rebuild the entire project or is there a simple way to swap the controller and keep all the modules and references intact?
Lawrence M. David Jr.
Certified LabVIEW Architect
cell: 516.819.9711
http://www.aleconsultants.com
larry@aleconsultants.com
(2,719 Views)
I can't find anything regarding a 9011 in our database. Either way, if you are changing the controller type, you will need to rebuild the build spec and fix your references.
Ben D.
(2,702 Views)
