Change Label or Caption Text of String Indicator
Can you change the String Indicator Label or Caption Text?  I tried this, but I keep getting the error "Property Node (arg 2)":
Can you tell me if changing the caption or label text is possible?
hiNi
(989 Views)
You should include the error code when posting the question. See Error 1320 When Setting a Caption Property for case 2.
You cannot run cases 1 and 3. See Programmatically Changing the Label for a Control or Indicator in LabVIEW
https://tmesystems.net/
(970 Views)
Changing a label of a non-idle control\indicator isn't allowed.
Showing\changing a caption works iff the control\indicator has a caption. That's only the case if the user created a caption.
A vanilla control\indicator doesn't have a caption. The 'caption.visible' property will give an error. The caption has to be shown once. From then on the control has a caption, and the caption can be changed while running, and shown\hidden freely...
(930 Views)
hiNi
Caption: Yes
Label: No
Qestit Systems
Certified-LabVIEW-Developer
(918 Views)
Accepted by topic author hiNI
The error is probably due to the caption object not existing.
Open the properties of the indicator and enter anything as a caption.  That will cause the caption object to be created.
Your code should work after that.
(888 Views)
