annulla
Visualizzazione dei risultati per
Cerca invece
Intendevi dire:
Change IP-number and Subnet-mask with LabView?
To upgrade the software on a CRio-System, the user needs to change some settings in the TCP/IP-configuration.
To simplify this task I think on a possiblity to do (and at the end redo) the changes in the TCP/IP-Configuration of the Windows PC.
What I need is:
- Change the IP-Adress (from "Obtain IP adress automatic" to IP xyz...)
- Change subnet-mask
- Redo this settings by saving an existing config or set to "Obtain IP adress automatic"
Who knows if and how it's possible to do that in LabVIEW?
Perhaps I have to call a script  /.bat-file?
LabVIEW 6,7 and 8 available 🙂
Messaggio 1 di 13
6.869Visualizzazioni
Try netsh and a bat file. Rename the first file to .bat.
Message Edited by unclebump on 08-23-2006 06:03 AM
Message Edited by unclebump on 08-23-2006 06:05 AM
Scarica tutti
Messaggio 2 di 13
6.867Visualizzazioni
hi there
you can use the netsh environment on the command line. for example
netsh set address name="LAN-Verbindung" source=static addr=10.0.5.99 mask=255.255.255.0 gateway=10.0.5.1
see windows help for more information.
Best regards
chris
CL(A)Dly bending G-Force with LabVIEW
famous last words: "oh my god, it is full of stars!"
Messaggio 3 di 13
6.862Visualizzazioni
Hi, its a really interesting stuff to read. Did anyone try doing it ?
One thing that I wanted to know was: How long does it take to do this ? Since Im using a time critical application, can this entire operation happen in 100 milli seconds ?
Will be glad to hear from you.
Sreedhar
Messaggio 4 di 13
6.152Visualizzazioni
Sreedhar
I have used this for a program that needs to have a host IP address for High sped cameras. I have it change the IP address to the required address and change it back when I am done. Here is a very simple Labview version of this code with out the switch back.
Tim
GHSP
Messaggio 5 di 13
6.135Visualizzazioni
Sreedhar
If you want to know how long it takes, run it yourself. You certainly do not need LabVIEW to run a DOS command. If I recall, it's going to be pretty dependent on your OS and pc. I also don't recall ever coming close to 100 msec but it's been a few years since I've done it and the timing was not at all critical for me.
Messaggio 6 di 13
6.117Visualizzazioni
You can set the system exec not to "wiat until complete". This will return an error code and you can react to that.
Tim
GHSP
Messaggio 7 di 13
6.106Visualizzazioni
Could you please explain me: "set the system exec not to "wiat until complete"."
Is it done in LabVIEW ? if yes, how and where.
I tried running this batch file on my PXI-8109, but it is taking some 3-4 sec. Any help to improve this will be highly appreciated. I need to complete the entire operation with-in 100ms.
Regds
Sreedhar
Messaggio 8 di 13
6.076Visualizzazioni
In the code that I sent the system exec is the VI that looks like this.
22679iC74230686D547832
The boolean that is on top is the wait until complete boolean. Set this to true and look for the return code.
22681i3C4C9C03F20381E5
Tim
GHSP
Messaggio 9 di 13
6.054Visualizzazioni
Sorry for the trouble. After I checked your code, I was pretty clear what you meant.
But, I'm still facing the timing issue, it is taking almost 2-3 seconds for its completion. By making the "Wait till Completion" as false, I am only releasing the CPU for my internal operations, but I cannot use the new IP address untill it is actually changed.
Thinking to implement virtual ip concept, will keep posting
thanks.
Messaggio 10 di 13
6.046Visualizzazioni
