Case structure wiring
Hi LabVIEW Folks,
I'm so interested to learn a quick wiring tip for case structure without having to wire manually for every single state. I know there is an option "use as default value" but I'm interested in actually wiring because I'd need this for shift register where values are different than default.
It is really frustrating to wire a new data value manually through every state in case structure.
For more resolution, I've attached VI.
Let me know if I'm not clear with my question. Thanks!
I know this forum always rocks. Appreciate all helps so far.
Jatin
(4,625 Views)
Hi Jatin,
since several LabVIEW versions you can right-click an output tunnel to make it a "linked tunnel"…
(4,621 Views)
Hi Jatin,
i feel very comfortable using Functional Global Variables
https://forums.ni.com/t5/Example-Programs/Basic-Functional-Global-Variable-Example/ta-p/3503982
not only for case structure but also for the whole project 🙂
(4,607 Views)
Accepted by topic author ackatharotiya
Linked Tunnels are what you are looking for.  They have been around since LabVIEW 8.6!
Just right-click on the output tunnel and there are a couple of options for linking the output tunnel to the input tunnel.  One of those options is to go ahead and wire all of the unwired cases for you.
(4,595 Views)
