Case structure of a typedefed enum
I have the following situation:
Normally, the case structure should offer named enum values for cases, but it doesn't. Can you tell what am I doing wrong?
I already tried with help of the type cast, coerce to type functions with no success.
Thank you!
(2,835 Views)
Accepted by ravyh
Your Command private data is not a enum, it might be as ring or just a number.
(2,829 Views)
Aha! you're right - it originally was and after changing it, the visual resemblance got me confused!
Thank you
(2,825 Views)
