08-04-2008 08:51 PM
08-04-2008 10:00 PM
08-04-2008 10:13 PM
Well, the there is no discernible pattern, you need to enter it all manually. Nobody else knows what goes where. If you have the values in a file, you could write some code that reads the file and generated the LUT.
I would use only a single array where the input string is converted to a number and used as array index directly.
For example for the following:
007A -> simon
0075 -> raymond
0045 -> johnson
001A -> monica
You would create an array with a few hundred elements. Elements are by default empty, but;
A(122) = simon
A(117) = raymond
A(69) = johson
A(26) = monica
In this case. Now just typecastcast the 2 bytes to a number and use it to index into the array to get the desired result. Even a 16bit LUT is peanuts for a modern computer.
08-05-2008 12:33 AM
Hi Simmy
I seems like you want you work to be done by someone else![]()
why dont you send ur data, so that someone around here will key in all those values in a file & send you the file.. lolz ![]()
08-05-2008 12:39 AM
08-05-2008 01:11 AM
Sorry Guys,
My intention was not to make feel anyone down & neither i wanted to make this thread a place for non-technical discussion. All it was, just a joke.
& Simmy If you felt bad for that, i apologise to that & i never said that i am perfect (no one is perfect).
Is there a way by which i can delete my Posts ????
08-19-2008 02:29 AM
