Case structure having String in hex display
     I am using a case structure to decide what I should do after getting the response from a device. The device feed back is string in Hex form, for example '0250 3F30 0D' (without the quote). The 02 is the <STX>, and 0D is the <CR> in ascii table. The whole return read <STX>P?0<CR>. I copied the  '0250 3F30 0D' to the case selector label but it did not work.How should I do?
Ryan
Message Edited by RyanWu on 06-18-2009 04:33 PM
(3,835 Views)
can you post your code or an example of your problem
thanks,
Harold Timmis
htimmis@fit.edu
Orlando,Fl
*Kudos always welcome:)
(3,831 Views)
Accepted by RyanWu
Change to '\' Code display and paste that into the case label. I don't think there is any way to use hex.
(3,827 Views)
Hi Dennis,
     Thanks. It worked.
Harold,
      The attached file is the example code.
Ryan
(3,784 Views)
