Case structure and event structure with an indicator (boolean) condition
@SEGIO wrote:
The problem is that I don't know how to close TDMS file completely, because I want to replace this TDMS file by the TDMS file generated in next acquisition.
ok, you still did not answer the questions completely ( about cycling,terminate, user interface?)...this vi will (step by step):
  • goto case statement 'acquisition1' and write data for 2 mins. , then close file in T/F case statement, goto case statement 'wait'
  • wait for 5 mins goto case statement 'acquisition2'
  • generate TDMS random data for 2 mins, goto 'wait'
  • cylcle through 'wait' and 'generate random data'.....
by the way,it is always a good practice to type def your case statement enums incase you have to add more statement commands...Smiley Wink
Spoiler
Message 11 of 37
(1,448 Views)
I don't know why you put an other state (acquisition 2). I've implemented your program and I can't see that last file is replaced. It's like acquisition has finished and it doesn't go on.
Otherwise, why I can not do that like this (open file and close file in case structures, in acquisition state), and leaving only 2 states (acquisition and wait)?
Thank you for your help
Message 12 of 37
(1,431 Views)
  • i added acq2 because you wanted "to replace this TDMS file by the TDMS file generated in next acquisition."
  • your vi is constantly opening a TDMS reference, because the elapsed timer outputs a false for 2 mins...not good!, leave it on the outside of the while loop
if you write a step by step explanation of sequences of what exactly you want done here...we can better understand your intentions Smiley Wink
Message 13 of 37
(1,424 Views)
Ok...I understand, thanks. But I've implemented your program and it doesn't work as I would like to, because the file created is not replaced. Have you run it?
Message 14 of 37
(1,416 Views)
ok...is this what you want?
  • case acqusition: create or replace file, write to file for 2 mins, close file
  • case wait: for 5 mins
  • case acquisition: replace file???...., write to file for 2 mins, close file
Message 15 of 37
(1,411 Views)
Yes, I'm sorry. And know I've seen that in case acquisition 2 there isn't close file, maybe it's the reason of it's not working.
Sorry and thanks
Message 16 of 37
(1,408 Views)
Have a look at the .llb that I've upload, it's yours but changing acq2 and adding a signal generated. The problem as you can see is that the second acq is not done, I can only see the first tdms file generated.
Thanks 😉
Message 17 of 37
(1,399 Views)
i see what you are doing...i am trying to understand you here Smiley Wink
is what you are doing is what i had mentioned in the previous post?...replace the file at every acquisition, then wait?
Message 18 of 37
(1,394 Views)
I want to make an acquisition of 2 minutes. Then stop 5 minutes (at this time I want to send the file generated previously using FTP). After this 5 minutes, start an other acquisition of 2 minutes replacing the file that was created in the first acquisition (because I've sent this file from to RT to PC, so I don't mind if it's replaced). And I want to do that infine times until I put stop 😉
Message 19 of 37
(1,391 Views)
see if this is what you want...
Spoiler
Message 20 of 37
(1,382 Views)
