motion control
Hi, I have decided on building a Automatic Solar tracker using NI 9505 modules and cRIO 9012. Where can I find the relevant studying material for the same.
p.s: I have started working on labVIEW since past 2 weeks... done with core 1, core2, some part of RT and FPGA.
(3,213 Views)
You have already gone through sufficient course material... Now its time to code...Smiley Very Happy!!
As of now, to implement an 'Automatic Solar tracker' you might already have the algorithm with you.. I would suggest you to start implementing it now and post your queries/issue (if at all you face any) in the forum to discuss it with others...!!
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
(3,196 Views)
facing trouble with the connections b/w 9505 module and servo..
could u give me some references..?
(3,192 Views)
Share detailed info on your setup:
what motor are you using??
Is there any custom interfacing circuitry in place...??
part/model numbers... etc
(3,188 Views)
I don know the model number of these servos ... they are old ones ....
I tried to connect module to servo via the receiver circuitry mentioned on the NI 9505 module .. (http://zone.ni.com/devzone/cda/pub/p/id/1259) circuit mentioned on the side face ... but doesnt seem to work..!!
(3,177 Views)
