Case selector from a truth table
We have a case structure with a set of cases and then we have boolean flags which describe the situatuation. we need to enter the case structure using a truth table. Forward, Backward and stop are different cases in the case structure.
Situation  |     case name
False True => Forward.
True True => Backward
False False => Stop
How may we do it? Please upload a VI if it is possible for you.
Message 1 of 11
(5,389 Views)
You could use a simple State machine
Message 2 of 11
(5,369 Views)
Boolean to 0-1 and add them to get 0, 1 or 3  (leave case 2 as default and throw an error "Undefined state command") to help you figure out how that True - False condition occured
"Should be" isn't "Is" -Jay
Message 3 of 11
(5,366 Views)
I imagine there is a better way to do owhat you want than what you are trying to do.  But you could use Build Array and the Boolean Array To Number.  You could then wire that number to the case selector.  For two booleans, you will have cases of 0 (F-F), 1 (F-T), 2 (T-F), and 3 (T-T).
Message 4 of 11
(5,354 Views)
Accepted by aan928
Or, Boolean Array to Number and show the radix in the Case structure.
2015-01-09 14_18_08-Untitled 3 Block Diagram on TCPT CAN ESS.lvproj_My Computer _.png
Jim
Message 5 of 11
(5,350 Views)
Darin wrote a truth table node a few years back. I never downloaded it, but it looked interesting...
http://forums.ni.com/t5/LabVIEW/Truth-Table-Node/td-p/1293680
Message 6 of 11
(5,313 Views)
Darin's truth node only has two options.  The OP needs at least three output possibilities.
They also need to determine what happens in the True False state.  Does that act the same as False True?
Message 7 of 11
(5,251 Views)
False False => Stop
You could do something like this but what about the True-False case?
You should be using "Radio Buttons" for this.
Radio buttons allow only one selection (or none) and it's output can be fed right onto a case structure.
=== Engineer Ambiguously ===
Message 8 of 11
(5,223 Views)
Radio buttons don't quite work that way.    You can have no selections when you first start, but as soon as you hit one button, you can never "unhit" it.  You'll always have one button pressed anytime after you've pressed any button for the first time.  You can only have the "false-false" condition up to the first time you ever hit any button.
Message 9 of 11
(5,191 Views)
 All you need to do is "right-click...allow no selection". 😄 Now clicking the currently active selection will uncheck it.
Message 10 of 11
(5,177 Views)
