Case Structure using Byte Array
Thanks for suggestion
There are 9 bytes which mean they are 72 commands.   If I did it your way I will only be able to do one command per bytes.  What happen if one byte has two high bits?  Like if byte 2 (element 1) has two high bits
Message 11 of 15
(1,647 Views)
That's what my post above attempts to address.
Bill
CLD
(Mid-Level minion.)
Message 12 of 15
(1,637 Views)
You can easily create a boolean array with 72 elements using some trivial modifications and do exactly want I described.
Message 13 of 15
(1,619 Views)
I used a combination of Altenbach and Jcardmody (jim) suggestions.
Thanks.
Message 14 of 15
(1,582 Views)
Thanks.
You know what would really show your appreciation to these guys?  Giving them kudos for taking the time to help you.  Checkout this link and the When you get the help you want section.
Message 15 of 15
(1,541 Views)
