Case Structure Sub Label bug ?
Searching the forum I could not find a post related to this.
Whenever something changes in the diagram LV marks the VI as not saved (yet).
However, when the Sub diagram label of a Case Structure is changed, text and/or visibility, LV does not mark the VI as not saved.
I think this is a bug.
Kees
(5,539 Views)
I agree, this is a bug.  I can duplicate this in LabVIEW 2013.
Kelly Bersch
Certified LabVIEW Developer
Kudos are always welcome
(5,495 Views)
Hello Kees,
I have tested it and it indeed seems to be wrong behavior
I am going to file a Corrective Action Request and I will post the tracking number over here.
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
(5,461 Views)
Accepted by topic author K C
Created CAR #438528.
Kind Regards,
(5,454 Views)
CAR 438528 discussed in this thread was fixed in  LabVIEW 2014.  For a more complete list of bugs fixed in LabVIEW 2014, check the LabVIEW 2014 Bug Fixes. You can download an evaluation copy of LabVIEW 2014 at www.ni.com/trylabview/ or if you have an earlier version of LabVIEW installed and an active SSP subscription, you will be able to download the latest version of LabVIEW through NI Update Service.
Jeff Peacock
Product Support Engineer | LabVIEW R&D | National Instruments | Certified LabVIEW Architect
(5,309 Views)
