Capture and save image using dotnet in labview?
I am doing a project where a trigger is sent to a camera. I want the camera to receive the trigger, capture an image and then save it automatically. I would be grateful if someone could help me with it.
-Nachiket
(4,285 Views)
Hi nachikulk,
Could you give us more information about the camera you are using and how you plan to control it?
Mitchell Faltin | NI
(4,224 Views)
I am using Ueye camera and my motto is to capture some images that are projected using a projector. This projector sends a trigger to the camera. What I want is whenever trigger is received by camera, it must be able to capture image and save it automatically. Since ueye vi are in .NET format, i am trying to save and capture using .NET formats.
Hope this helps.
Thank you
(4,216 Views)
Accepted by nachikulk
I don't know exactly what you are doing, but I think this .Net code might help.  It opens a file into a bitmap image, resizes the image, creates a new memory stream, then saves the image into the memory stream and returns it.  You could write this array of bytes to a file using the Write to Binary File.
(4,195 Views)
Thanks!!
(4,163 Views)
