01-15-2009 04:06 PM
I can't locate the image processing vi's even though I've just installed Vision development 8.2.1. I'm looking for vi's like "IMAQ Histograph", "IMAQ Extract" etc...
Other categories like "NI-IMAQ " and "Vision Utilities" seem to have installed fine and I find them on the function palette. It's just the Image Processing one that seems to be missing.
I've done a search for the vi's in the "National Instruments" directory but have come up empty.
Appreciate any help, thanks!
01-16-2009 11:25 AM
Hey ptuinluff,
What version of LabVIEW are you looking for these palettes in? You need to have the same version (8.2.1) or earlier to work with Vision 8.2.1. Also, have you manually checked that the llbs are not there? The default path should be
C:\Program Files\National Instruments\LabVIEW X.X\vi.lib\vision
Where the X.X is your version of LabVIEW.
Also, I would verify that you have Vision installed in your NI License Manager. As those other VIs that you mentioned are installed with Vision Acquisition Software, not Vision Development Module. (VAS Actually installs WITH VDM, but VAS can actually be installed seperately also)
01-16-2009 12:41 PM
I see...that must be the problem. I am using a later version of Labview (8.5.1).
Thanks for the help!
