Running python script
I am trying to run a python script in labview. I downloaded python 2.6 and the open g python tools. The python script requires 3 inputs and it creates an output file. I have added the 3 inputs and file ouput to the python script node. I get an error message "LabVIEW:  LabVIEW cannot initialize the script server.  Ensure the server software is installed. in PYTHON Script Node__ogtk.vi". What am I doing wrong?
(6,133 Views)
Try using Python 2.5; I had trouble with 2.6 and had to step back.
If you'd like, post your code and I'll see if it runs for me.
</jim>
Jim
(6,111 Views)
(6,106 Views)
Here is the code. The values that need to be specified are 'cheight' (could be a value of 1000), 'cpressure' (could be 800) and 'ctemperature' (could be 10). An output file should be created with calculated values. The code should be invoked as follows:
Options:
-h, --help show this help message and exit
-F CHEIGHT, --cloudbaseheight=CHEIGHT
Cloud base height
-P CPRESSURE, --cloudbasepres=CPRESSURE
Cloud base pressure
-T CTEMPERATURE, --cloudbasetemp=CTEMPERATURE
Cloud base temperature
-o FILE, --output=FILE
write output to FILE
(6,079 Views)
I got this error: Error 1050 occurred at PYTHON Execute Script__ogtk.vi->Untitled 3:, global name 'OptionParser' is not defined
That tells me that I'm not getting the library, but am getting Python.
Jim
(6,062 Views)
Can you save this for Labview 8.5 version and repost?
(6,058 Views)
8.5
Jim
(6,052 Views)
