Cannot use USB 6008 in Lab VIEW... is in Devices on Comp however
I was in class the other night, and was running a VI.  We went to lab, and without shutting down labView, my partner plugged in my USB-6008 DAQ.  SInce that time, the 6008 will not show up.  I have a message about having no supported devices.  I am using DAQmx 8.0 that came with my student version, and have reinstalled the LabVIEW 8.0 and the DAQmx 8.0  I still cannot get LabVIEW to recognize the DAQ.  When I plug it in my hardware profiles recognize that it is hooked up, but LabVIEW will not.  Also I have uninstalled it, and plugged it in, reinstalled it using the auto hardware install wizard, and still nothing on LabVIEW.  The DAQ has the flickering green LED, and works on other laptops.  Also my flash drive works correctly in all of the USBs, so I do not think that could be the problem.  I just really would like to get this to work again, but as I said the DAQ is not recognized by MAX or DAQmx inside of LabVIEW.  Any help would be greatly appreciated...
(2,501 Views)
You might want to try MSI-Blast.
Have a look at this thread.
http://forums.ni.com/ni/board/message?board.id=170&message.id=108288&query.id=113978#M108288
Patrick Allen: FunctionalityUnlimited.ca
(2,496 Views)
