Cannot set floating point to zero
I have a numeric control where I want to set the Digits of Precision to zero.  In Numeric Properties, I set Format and Precision to Floating Point, Digits = 0 and Precision Type to Digits of Precision.  When closing the Properties dialog however, the number of decimal points returns back to the number of decimal point before making the change.  I can get the numeric control to display decimal point greater than zero, but not zero.  I just installed LV v.8.20.
What am I doing wrong?
DJ
(3,959 Views)
See reply 10 of this thread
http://forums.ni.com/ni/board/message?board.id=BreakPoint&message.id=2859&jump=true
This sounds like a previously reported bug.
Ben
(3,948 Views)
DJ
Hi DJ,
No, you just found a bug (look here) You can trie to use the integer display format.
Ton
PS Smiley Mad why Ben why
Message Edited by TonP on 11-06-2006 09:40 PM
My LabVIEW Ideas
(3,947 Views)
Hi DJ,
I just discovered the same thing myself with a numeric indicator in LV 8.2.  It seems like it won't let it set to zero, but returns it back to the previously set value, which may be 1 or 6 or something else.
The good news is it works properly in LV 8.2.1
(3,838 Views)
Yes, I upgraded to v.8.2.1 and the problem is now fixed.  Thank you for your follow up.
Dave J.
(3,830 Views)
