Cannot open connection in a peer-to-peer netword
Thanks very much. Appreciate the help along the way.
Message 11 of 13
(659 Views)
Scott,
     This post is two months ago, don't know if you still remember.
     I set up the PDA ip to be 192.168.1.X, it works for TCP/IP functions; but now when I tried UDP functions, it does not connect again. Here is the link to another post. Can you help find the problem?
 http://forums.ni.com/t5/LabVIEW/PDA-only-receives-UDP-data-when-connected-to-PC-fails-wirelessly/m-p...
Message 12 of 13
(606 Views)
It looks like Verne is taking care of this issue and will help you answer these questions.
Applications Engineer
Message 13 of 13
(595 Views)
