Cannot install software on cRIO 9076
Hello nhatnguyen1001
So, i need to connect the cRIO with PC through a hub in the same subnet mask and same IP.
My problem was in the network cable which is connected in the dock and not in PC. This don't allow the connection between cRIO and MAX to do installation of software, but allow to format... Strange Thing...
With cRIO connected to hub and PC connected directly to hub too the problem is solved!
André Simões
Work with LV2019 and cRIO since 2021
Message 11 of 11
(298 Views)
