Cannot get latch mechanical action on boolean button inside a cluster
@JensG69 wrote:
I keep saying "alongside" since my example contains several events for the differents latched buttons inside the cluster.
We all agree that a latched button will only reset when LabVIEW according to dataflow accesses the terminal. Since my example contains several events I cannot place the cluster inside every event case. Only solution: Place it parallel to the eventstructure (or in a flat sequence after the eventstructure) and hope that the code inside the events does not wait.
Cf. attached VI:
Regards, Jens
Then this is a bad design choice from the beginning. Use a single Event Case for your cluster. Simple and compact. I think it is not good to show such examples specially to beginners, since they will learn to use it...
EDIT:
here is a snippet using a single Event Case:
Message 11 of 17
(1,747 Views)
@Blokk:
I certainly agree that using several latched buttons (or even one latched button) inside a cluster is not the optimal design choice. But alas it seems the OP did something like this and now has problems. I only try to give a solution of what I believe is the source of the problem in the VI of the OP. Unfortunately he did not upload his code up to now so we are all guessing.
I disagree that it is always a bad design choice to define events for elements of a cluster. I think defining events for elements of a cluster makes the code more readable.
Regards, Jens
Kudos are welcome...
Message 12 of 17
(1,735 Views)
@JensG69 wrote:
@Blokk:
I did not say this. I said it is a bad design not putting the Cluster control into a (single) Event case. There is nothing wrong to use several Boolean buttons (with "Latch until release" mechanical behaviour, as this is the common usage) inside a Cluster, I do this all the time!
Well, in my opinion the code is more readable if you use a single Event Case for a cluster, since we have this option. You read out the control in the proper place, and it is also very easy to compare old/new values and get the index of the button which value got changed. I cannot imagine a more simple way to do this right now...
Message 13 of 17
(1,726 Views)
How silly.  If you have a Cluster whose elements are all Latch until Released Booleans and you do (as GerdW and I both suggest) put the entire Cluster inside its own Value Changed (for the entire Cluster) Event,  Since you can Mouse Down on only one button at a time, any Button Click will "turn on" exactly one button, and it should be pretty trivial exercise to figure out which one.  You can do a single Cluster Element, or the entire Cluster in an Event, but be sure that the entire Cluster is in each Event that involves it.
Don't they drill this idea into discussions of Boolean Latches and Event Structures any more?
Message 14 of 17
(1,714 Views)
You can always emulate a latched button by setting it to switch when released, then setting the value to FALSE by using a property node in the event case.  This would work well if the button is inside a cluster.
Bill
CLD
(Mid-Level minion.)
Message 15 of 17
(1,701 Views)
In such case, use a local variable to set the value of the control, better to avoid property nodes for setting control values...
Message 16 of 17
(1,693 Views)
As to using 1 event for a cluster or many for its elements, i'm 50/50. It depends on what's happening inside the event and how messy it'll be. So basically, the tidier one.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 17 of 17
(1,685 Views)
