Cannot debug remote application
I seem to be having issues with debugging remote application and I am not sure what could be causing this.
I followed these instructions for setting up the exe to allow remote debugging:
Remotely Debugging Executables in LabVIEW - NI
When using the 'Debug Application or Shared Library' window, I can find the exe on the remote machine, but when trying to connect to it, the connection hangs (see screenshot below). I cannot cancel the connection, close the window or use labview - I have to stop the remote application through task manager (closing through 'X' does not fully close it), after which I can use labview as normal on the host machine
The application itself on the remote machine seems to stop as well after attempting remote debug. I can press buttons but they don't do anything. If I then restart the application, it works as expected.
I then tried doing the same thing on localhost with the exe open locally. But I get a generic "Failed to connect to remote application".
I'm using LabView 64-bit 2021 SP1.
I also checked if the port was working by typing http://localhost:3580/dumpinfo? into the browser. Everything seems to be ok here as well, as far as I'm aware.
Has anyone come across this before?
Thanks very much for your time.
Message 1 of 22
(7,013 Views)
Hello, RT_Instron. What hardware do you use?
Message 2 of 22
(6,971 Views)
I have the exact same issue. LV2020 SP1 works but not 2021 SP1.
http://localhost:3580/dumpinfo? works
Turning firewall off doesn't help.
If I create an empty test VI and build it with debugging enabled and connect to it I get:
I have followed this: Remotely Debugging Executables in LabVIEW
I
Certified LabVIEW Architect
Message 3 of 22
(6,966 Views)
Ok, Can you show me your Project Explorer?
Message 4 of 22
(6,959 Views)
Do you want to debug from PC the Real-Time Application, or you want to debug from one PC, to another PC project?
Message 5 of 22
(6,952 Views)
I checked with LabVIEW 2020 and LabVIEW 2021, It works. Now I am downloading LabVIEW 2021 SP 1 for test in this version.
Message 6 of 22
(6,939 Views)
I don't know about the OP, but I just tried on the same PC. Attached buildable project.
Message 7 of 22
(6,935 Views)
Thanks for getting back to me.
I'm trying to debug from one PC to another PC. So in terms of hardware, there's no additional NI hardware involved.
I tried doing the same thing as thols where I created a new project with a really simple VI with a while loop and set up the build spec to enable debugging. But I get the same result as in my original post.
Trying with exe on localhost: "Failed to connect to remote application"
Trying with exe on external computer: hangs on "Downloading NI_FileType.lvlib" until the remote exe is forced to exit.
Hopefully that helps. Please let me know if there's any info I can provide to diagnose the issue.
Message 8 of 22
(6,923 Views)
I tried remote debugging in LabVIEW 2021. It works great. Now I am downloading LabVIEW 2021 SP 1 for checking.
Message 9 of 22
(6,918 Views)
Hi, I tried on LabVIEW 2021 SP1. The problem occurred. The first time I couldn't find the application, the second time couldn't connect.
Message 10 of 22
(6,866 Views)
