Cannot create build - Icon could not be written
I have an older LabVIEW project that's been converted from LabVIEW 2012 to LabVIEW 2017. When I run the code, it compiles and runs just fine, but whenever I try to build an .exe, I get the following error:
The icon at C:\Test\src\SplashIcon.ico could not be written to the application. Verify the icon is at the expected location. If using the default icon, please contact National Instruments technical support with this information.
Click the link below to visit the Application Builder support page. Use the following information as a reference:
Error 1 occurred at AB_Engine_EXE_Call_Write_Icons.vi -> AB_EXE.lvclass:Build.vi
Possible reason(s):
LabVIEW: An input parameter is invalid. For example if the input is a path, the path might contain a character not allowed by the OS such as ? or @.
This happens if I use the default icon as well. The SplashIcon.ico works perfectly fine in another, much smaller LV2017 project. I have tried:
  • Creating a new project and copying in the files
  • Closing the file explorer completely
  • Using a build path with no spaces in the path
  • Creating the Build Specification from scratch
  • Changing settings in the Build Specification
  • Running Mass Compile
  • Restarting my computer
  • Using a different computer completely to build
  • Running LabVIEW as Administrator
  • Building other projects (they work)
But all of these do not change the outcome. I still get the icon error.
On top of this, I have a slightly older version of the same code that I used to be able to build (I have an exe), but now when I try to build it, I get this icon error. Initially, I thought this meant I had a problem with my Application Builder, but I am able to build other projects, and my teammate is also unable to build this project.
Any suggestions?
Message 1 of 17
(5,970 Views)
I'm still having this issue, and I don't think there is a way to just reinstall Application Builder, so I'm going to try reinstalling LabVIEW completely.
Message 2 of 17
(5,887 Views)
Start with this article: The Icon "lvapp.ico" Could Not Be Written to the Application
Message 3 of 17
(5,882 Views)
From that article:
There are several potential causes of this error, all relating to the location of your application build folders.
  • Make sure the location of your build or build folder is not open in a Windows Explorer window.
  • Make sure the the same build folder for multiple versions of the same application is not reused. If you need to update and re-build a project, use a new folder name.
    • This can be done using Version Tags to automatically append a version number to the folder name.
  • If you aren't using version tags, un-check Auto Increment Version Number in the Version Information tab of the Application Builder.
  • Changing the build destination folder to above the Windows User level.
  • Perform a Mass Compile of the project.
  • Try building just a blank application to see if the problem persists regardless of project.
  • Some characters in file names are known to cause weird errors, such as \ / : * ? " < > | . Make sure these characters do not appear in the names of VIs or files that are in the project.
  • Replace lvapp.ico with a copy from a working version of Application Builder.
  • Try force reinstalling LabVIEW Application Builder.
  • Re-install LabVIEW.
I have tried everything on the list except the two re-installation options. It recommends force re-installing Application Builder, but looking at my LabVIEW DVDs, there is not a LabVIEW Application Builder setup.exe anywhere. I am going to try re-installing LabVIEW completely next.
Message 4 of 17
(5,879 Views)
Upon starting the installation process, I was reminded that I installed LabVIEW NXG 4.0, and it required me to install quite a few 2019 versions of NI software. My coworker who is also experiencing this problem also has the same setup. The last time I successfully built this project was before I installed NXG, so I think something in that installation messed up something.
That said, I am uninstalling all NI software, LabVIEW 2017 and LabVIEW NXG 4.0, and I will perform a clean install of LabVIEW 2017. This will likely take a day or two, but I will report back if this works or doesn't.
Message 5 of 17
(5,871 Views)
Update:
Reinstalling LabVIEW 2017, with NXG removed, did not fix the issue.
Any ideas?? The only thing I think I can do is take everything and copy it all into new VIs in a new project, but that will take very long and I would like to avoid it.
Message 6 of 17
(5,820 Views)
Did you read the link for "force reinstalling"?  It discusses using NIPM to reinstall, not running a setup file.
Bill
CLD
(Mid-Level minion.)
Message 7 of 17
(5,810 Views)
It says to use NIPM if you installed with NIPM, but I used the product DVDs to install LabVIEW 2017.
Regardless, I did a complete uninstall and then a clean install, following these steps https://forums.ni.com/t5/LabVIEW/How-To-Safely-Completely-Remove-LabVIEW-2018/td-p/3811269?profile.l...
Message 8 of 17
(5,804 Views)
I wasn't aware that LV 2017 was available on a DVD.  I thought that it was around that time when they made the switch to USB stick and everyone was grumpy because of that.
Bill
CLD
(Mid-Level minion.)
Message 9 of 17
(5,788 Views)
Thanks for that link - I'm going to make use of it right now because I'm going to uninstall all my pre-LV 2020 stuff and install the Community Edition.  You just saved me time searching for this exact link.
Thanks so much!
Bill
CLD
(Mid-Level minion.)
Message 10 of 17
(5,784 Views)
