‎04-23-2020 01:48 PM - edited ‎04-23-2020 01:55 PM
I have an older LabVIEW project that's been converted from LabVIEW 2012 to LabVIEW 2017. When I run the code, it compiles and runs just fine, but whenever I try to build an .exe, I get the following error:
The icon at C:\Test\src\SplashIcon.ico could not be written to the application. Verify the icon is at the expected location. If using the default icon, please contact National Instruments technical support with this information.
Click the link below to visit the Application Builder support page. Use the following information as a reference:
Error 1 occurred at AB_Engine_EXE_Call_Write_Icons.vi -> AB_EXE.lvclass:Build.vi
Possible reason(s):
LabVIEW: An input parameter is invalid. For example if the input is a path, the path might contain a character not allowed by the OS such as ? or @.
This happens if I use the default icon as well. The SplashIcon.ico works perfectly fine in another, much smaller LV2017 project. I have tried:
But all of these do not change the outcome. I still get the icon error.
On top of this, I have a slightly older version of the same code that I used to be able to build (I have an exe), but now when I try to build it, I get this icon error. Initially, I thought this meant I had a problem with my Application Builder, but I am able to build other projects, and my teammate is also unable to build this project.
Any suggestions?
‎04-27-2020 10:22 AM
I'm still having this issue, and I don't think there is a way to just reinstall Application Builder, so I'm going to try reinstalling LabVIEW completely.
‎04-27-2020 10:56 AM
Start with this article: The Icon "lvapp.ico" Could Not Be Written to the Application
‎04-27-2020 11:02 AM
From that article:
There are several potential causes of this error, all relating to the location of your application build folders.
I have tried everything on the list except the two re-installation options. It recommends force re-installing Application Builder, but looking at my LabVIEW DVDs, there is not a LabVIEW Application Builder setup.exe anywhere. I am going to try re-installing LabVIEW completely next.
‎04-27-2020 12:09 PM
Upon starting the installation process, I was reminded that I installed LabVIEW NXG 4.0, and it required me to install quite a few 2019 versions of NI software. My coworker who is also experiencing this problem also has the same setup. The last time I successfully built this project was before I installed NXG, so I think something in that installation messed up something.
That said, I am uninstalling all NI software, LabVIEW 2017 and LabVIEW NXG 4.0, and I will perform a clean install of LabVIEW 2017. This will likely take a day or two, but I will report back if this works or doesn't.
‎04-29-2020 09:44 AM
Update:
Reinstalling LabVIEW 2017, with NXG removed, did not fix the issue.
Any ideas?? The only thing I think I can do is take everything and copy it all into new VIs in a new project, but that will take very long and I would like to avoid it.
‎04-29-2020 01:58 PM
Did you read the link for "force reinstalling"? It discusses using NIPM to reinstall, not running a setup file.
‎04-29-2020 02:24 PM
It says to use NIPM if you installed with NIPM, but I used the product DVDs to install LabVIEW 2017.
Regardless, I did a complete uninstall and then a clean install, following these steps https://forums.ni.com/t5/LabVIEW/How-To-Safely-Completely-Remove-LabVIEW-2018/td-p/3811269?profile.l...
‎04-29-2020 07:11 PM
I wasn't aware that LV 2017 was available on a DVD. I thought that it was around that time when they made the switch to USB stick and everyone was grumpy because of that.
‎04-29-2020 07:13 PM
Thanks for that link - I'm going to make use of it right now because I'm going to uninstall all my pre-LV 2020 stuff and install the Community Edition. You just saved me time searching for this exact link.
Thanks so much!
