Cannot change precision of digital display of a numerical control
This may be a stupid question. But in the attched slider control, I am unable to set the precision of the digital display. I can only set the precision of the scale. What do I need to do? Thanks.
Peter
(3,272 Views)
In the upper left of the display format tab of the properties dialog box, select digital display.
I agree that it could be implemented better, for example if you right-click on the digital display ...display format. it should land on the dialog with the digital display selected. It currently does not.
(as a general rule, you should avoid overlapping controls. It hurts redraw performance)
(3,263 Views)
