Cannot add Labview Runtime to Installer.
I cannot have the Labview Runtime Engine automatically installed by the installer created with LabView, even if the "Install LabView Run-Time Engine" is selected in the advance installer settings.
(2,964 Views)
This seems odd.
THe Run-Time engine is not used in the development environment so I have to ask,
Is the Run-Time engine installed on the machine you are trying to do the build on?
Installing the Run-Time engine is an option available durring install time.
that's my 2 cents worth.
Ben
(2,964 Views)
