Canceling the "File Dialog" and handling the errors caused by the empty path which establishes DB connection
Hi GerdW
Thanks for your BIG tip!! I do think dataflow, otherwise I couldn't use labview.
Message 11 of 18
(1,536 Views)
Hi lman,
When you use local variables to "clean up" a block diagram you DON'T think DATAFLOW!
Message 12 of 18
(1,512 Views)
Hi GerdW
it depends, what a "cleaned up BD" means for you!
But I know using the local variables in VI does not necessarily mean that user doesn't think data flow.
Message 13 of 18
(1,496 Views)
@Iman1988 wrote:
Hi GerdW
ROTFL.
And you are arguing data flow with GeradW???  Seriously?
Message 14 of 18
(1,487 Views)
Hi nyc
No, I don't argue with him or anyone else. I respect his knowledge as an expert in LV and I already know that our LV knowledge are not comparable.
But apparently he gets pissed off early when you ask an easy question and repeat it more than once.
The reason that I asked my problem here, was to get my answer and learn something from the experts like GerdW. And actually I was expecting a better approach than this.
Message 15 of 18
(1,474 Views)
Hi lman,
I'm not "pissed off" - I even wouldn't use these words in a public forum…
Yes, you did that. And I gave you the answer in pseudocode, but you weren't able to work with pseudocode.
And you weren't able to implement your logic in LabVIEW…
You only have to sort out where to place a case structure and a while loop.
Don't you think you should start over with a simple VI to have that simple algorithm running - before implementing the DB stuff?
Message 16 of 18
(1,459 Views)
Hi GerdW
You are right. I may shouldn't have used such words in a public forum. So, I'm sorry.
Today, again I looked at your first reply and I solved the problem by using a while loop around the event structure and a case structure where the "Cancelled" is wired to the selector and rest of the codes including opening and closing the DB connection block in the False case.
Yesterday I was really tired and I think it was why I couldn't follow such easy logic.
I have question regarding one of your tips:
You suggested me not using local variables. Would it be better to use the value property node when we need to read or change the value of a control/indicator instead of its local variable?
Message 17 of 18
(1,441 Views)
Hi lman,
No…
Usually you don't need locals (or "value" properties): use wires instead. When you want to implement something like an "increment" style function: use a shift register to store the value!
You only need can use locals to initialize a control, but this most often is a "one-time-only" operation…
Message 18 of 18
(1,411 Views)
