Canalyzer database.dbc can't be accessed
Good morning,
I want to load à Canalyser configuration stored in a database.dbc ,but i dont succeed.I try many things but i can just load a cfg configuration.
(4,391 Views)
Unfortunately, Canalyzer is a Vector's software, that you try to control with ActiveX.
We don't know the ActiveX of this software, so we are unable to help you using this ActiveX.
First, if you have the documentation af ActiveX control of Canalyzer, you should take a look at it and try to find more informations on the possibility to use a cfg in a .dbc, then find the function that can do it.
Otherwise, please ask to Vector if they can help you on that issue.
Or maybe somebody on the forum already know the CANanlyzer ActiveX, and is going to help you. I hope so.
Olivier L. | Certified LabVIEW Developer
(4,365 Views)
