Can you install the 32-bit program into a 64-bit computer?
I am a student and want to buy the student version but I only found the 32-bit program and I have a 64-bit on my compute
(2,465 Views)
Did you try a search? This question has come up before. NI also has a Knowledge Base article on the subject. As a student, you should learn to search first. The answer to your question is yes, you can install the 32-bit version on a 64-bit computer, whether that computer is running a 32-bit OS or a 64-bit OS. It will work as a 32-bit program.
(2,463 Views)
