Can two parallel while loops have the same stop control?
hi guys,
This question may be trivial or stupid, but I can't get it out of my head.
Can we call two separate while loops doing separate things yet communicating with each other "Parallel Loops"?.
What is the difference between having a duo core processor in running parallel loops and running two separate while loops on a single core processor? I was reading this tutorial on ni.com "Improving Performance with Parallel For Loops" and this sparked this doubt in my mind. From reading this article, what I get is that parallel loops is basically running a single loop by sub dividing it into more loops using the duo core advantage. Is my assumption right here?
Thanks!
V
I may not be perfect, but I'm all I got!
Message 11 of 23
(2,923 Views)
Two different questions:
Communicating with parallel loops: there are lots of methods, and this question gets asked all the time. It was asked just recently, in fact. Just do a search and you'll find many suggestions, including global variables, queues, notifiers, etc., depending on what you're trying to accomplish.
Regarding parallel loops and multiple cores: what is your doubt? The article is fairly self-explanatory. If you have multiple cores then you parallelize a loop so that work can occur on more than one core at the same time. Prior to 2009 you'd have to manually create parallel for loops. The LabVIEW compiler would be smart enough to run each one on a separate core, if your computer had more than one core.
Message 12 of 23
(2,914 Views)
Ok! to simplify the question, Can the loops in the image shown be called Parallel loops? Would they run simultaneously? Or is Parallel loops a whole another thing related to cores of the processor?
V
Message 13 of 23
(2,904 Views)
Yes. They'll run in parallel.
Do the experiment: run the vi and watch the task manager. Two cpus will be at 100%.
Message 14 of 23
(2,890 Views)
That actually didnt quite answer my question, but I get what you said!
V
Message 15 of 23
(2,884 Views)
Why not? Seems perfectly clear to me, and this is even documented, so I don't understand what kind of answer you're looking for.
Message 16 of 23
(2,880 Views)
The concept parallel loops; Is it that a SINGLE loop can be run faster using different cores of the machine? (as in parallelizing)
as opposed to
the diagram that I showed before: Running two loops on a single core processor.
(One Loop, two cores or two loops, one core or two loops, two cores )
V------J
Message Edited by VeeJay on 04-14-2010 01:57 PM
Message 17 of 23
(2,875 Views)
I guess its a matter of language.
  1. Several loops (for and while, and timed) can run in parallel if they have no data dependency.
  2. New in 2009, there is the "parallel FOR loop" that can execute several iteration at once on multiple CPUs if the code allows (e.g. if each iteration is independent).
  3. Even a single loop can use multiple CPUs, for example if the loop diagram contains operations that can execute in parallel.
  4. A timed loop can be assigned to a certain CPU if desired.
Message 18 of 23
(2,848 Views)
Thank you! That clarified a lot!!
_________________________________________________________________________________________
quote "Several loops (for and while, and timed) can run in parallel if they have no data dependency. "
What if they do communicate with each other (having data dependency) in terms of one loop sending the command to another and the other sending its feedback?
Thanks! 🙂
VJ
Message Edited by VeeJay on 04-14-2010 02:38 PM
Message 19 of 23
(2,843 Views)
Any "wireless" data dependency is fine. Of course things will not be synchronous.
(The details can be more complicated. For example if you use queues, the consumer loop may need to wait until the produce loopr places something into the queue, etc.)
(I was talking about a flow dependency, for example if a wire goes from one loop to the other. The second loop can only start if all inputs have data, which only occurs once the first loop has completed.)
Message 20 of 23
(2,837 Views)
